I am looking to use the command line mode to open a e57 file ( single e57 file containing two clouds) change the -SF_COLOR_SCALE to a custom xml file and save the clouds as a .bin file.
I am getting the desired results when working with file paths with no spaces for the save file path. I am putting the file paths inside quotation marks (") but experiencing issues getting the file to save when a space is present in the save file path.
The following error is give: Invalid parameter: specified 2 file names, but ALL_AT_ONCE is on
This is an example of the commands i am using, entered as a single string in Command Prompt:
"C:\Program Files\CloudCompare\CloudCompare.exe" -AUTO_SAVE OFF -O "C:\Users\Example\Example\Example\20211110_204859.e57" -SET_ACTIVE_SF 0 -SF_COLOR_SCALE "C:\Users\Example\Example.xml" -C_EXPORT_FMT BIN -SAVE_CLOUDS ALL_AT_ONCE FILE "C:\Users\Example\Example\Example\Example\New folder\20211110_204859"
Any advice on what is causing this issue would be greatly appreciated.
I am using windows and Cloud Compare v2.11.3 (Anoia) [64-bit]
Regards James
