Sensor TLS data.
larderArch
Sensor TLS data.
Post by larderArch »
Hello, I can't find the way to export all the data [TLS / GBL Sensor] of all the clouds at the same time, is there a way? Basically I would like to obtain an x, y, z file with the scan center locations of each cloud contained in a CloudCompare file. Thank you.
TLS/GBL POINT SENSOR STATION
Cloud Compare TLS/GBL DATA
Re: Sensor TLS data.
Hum, sadly there's no way to do it currently... Apart if you hack the code of course (or maybe via Python and CloudCompy?)
