Using command line to apply a colour scale / Changing histogram font size
tbere9
Post by tbere9 »
Hi all,
I have a bunch of STL meshes saved in a BIN file which I need to apply a specific colour scale to. All of the STL meshes have undergone cloud-to-mesh distance computation, so they have a scalar field that shows the error of each STL file relative to a single reference STL.
Is there any way to use command line to apply a single colour scale which I have created to all meshes within the BIN file? Alternatively, would this work if the STLs were saved as separate BIN files which I could recompile later? I tried different variations of this without any luck:
  • CloudCompare -M_EXPORT_FMT BIN -O E:\Scalar_Test\STL_File.bin -SF_COLOR_SCALE E:\Colour_Scale.xml
I was also wondering whether there is any way to change the font size of the histogram axes/axis labels? They're a bit too small at the moment.
Appreciate the help!
Re: Using command line to apply a colour scale / Changing histogram font size
I fear that the current -SF_COLOR_SCALE option only works on clouds! And not on meshes...
I updated the latest version of CloudCompare 2.13.alpha online so that it can also work on meshes. Hope this will be sufficient.
