Dear Daniel,
Can I set my camera in a constant speed?
(I mean when the camera pass through the same length, It will spend the same time.)
Thank you so much!
Animation: Can I set my camera in a constant speed?
Re: Animation: Can I set my camera in a constant speed?
I have same issue...
sudden acceleration in camera speed
you can set the duration of every steps in the render dialog.
choose the view point and set the duration.
- QAnimationPluginDialog.jpeg (65.58 KiB) Viewed 2447 times
In animation child window ,How to use ctrl + A to select all viewports to assign i.e. 2 sec for all?
In alpha version during selecting views , and zooming-in part of the mesh disappears
when segment mesh then clicking (zoom and center selected entity ) ,mesh disappears (bug)?
That's not possible currently.
But you can change the overall duration of the animation, and it will change all steps in a proportional way I believe.
And for the bug report, I'm not sure to understand? Does it do this with any mesh on your side? Are you using the latest version?
