Hi im only new to using cloudcompare and would like to see a couple of things added if at all possible.
1. In the segment tool, the selections only have an option for a rectangle or polygon. Is there any chance to add a circle option please. I have to cut out trees from data or more the base of a tree when the CSF filter doesnt remove all of it.
2. Any chance you can have an option to confirm delete of a data file in the DB Tree, this can help in the case of accidentally deleting them.
Love the software and looking forward to learning how to use it better.
Segment tool & confirm delte
Re: Segment tool & confirm delte
I added these suggestions to the (way too long) TODO list.
While the 'circle' option has some chance to be implemented, the other one might be too annoying to a lot of users. But maybe an 'Undo' option would solve this issue as well ;)
i will put my vote for a circle selection/segment tool. I would use it regularly
