hello,
I would like to ask about how to find the area using 2.5D Volume.
Is the Surface in Results the area of a 2.5D grid (plane)?
I calculated the area of the rock with 2.5D Volume.
It seems like a calculation result that ignores the unevenness of the rock and flattens the surface.
Is the height range of the unevenness not calculated?
Sorry if this has already been posted.
About 2.5D Volume Surface
Re: About 2.5D Volume Surface
check attached example
To find real 3d shaped area ,you can mesh it and then use measure surface
edit -->mesh-->measure surface
DA523 Hello
Thank you for the easy-to-understand examples.
Thank you for also showing me how to solve the area.
