mesh question
Demonocracy
mesh question
Post by Demonocracy »
Hello. I have scanned a section of pipe, both internally and externally. I have generated a mesh from the points, showing the internal and external surfaces - this pipe has areas of corrosion so the mesh is thinner in some parts than others. My question is if there is anyway to colour the mesh by thickness (i.e. distance between internal and external walls. At the moment it is all a single mesh.
Re: mesh question
Are you able to split the original cloud or the resulting mesh into two parts? I guess that's your question? :D
DA523
Re: mesh question
Post by DA523 »
example.zip
(1.04 MiB) Downloaded 174 times
Can we work on this example?
then Tools--> Distances
then result in SF
pipe distance.png (106.41 KiB) Viewed 1037 times
