CC slows down quickly after several times segmenting
Hello. I've been using CloudCompare to segment 3D point clouds and it's been working well. However, after several times segmenting (which also involves zooming in/out and rotating the point cloud), the program slows down tremendously. I suspect there is a memory leak somewhere. I have tried both Linux and Windows version and they both have the same problem of slowing down. Does anybody have the same problem? How do I solve this? Thanks.
Re: CC slows down quickly after several times segmenting
This one is a little bit weird. I'll try to reproduce it on my side (maybe a vbo issue once again though).
I unticked "Try to load points on GPU.." option in Display settings and it helped alleviate the lagging problem, but didn't solve it. CC becomes progressively slower, but at a reduced rate. I am using the Linux version, if that helps.
I can confirm this issue on Win 7 (CC v.2.6.1.beta).
