Sorry for a question, it is a stupid question, but I don't remeber it or I can't find it after new update. How can I get the size of a simple plane or primitive inserted by the software? For example x=3.51 and y=6.3.
Thank You Very Much!!!!
Size Primitives
Re: Size Primitives
Well, that's silly but the plane dimensions can't be found easily right now (you can force the display of the plane vertices - you have to enable the cloud AND set a 3D display in the 'Current display' field - then increase the size and measure the distances with the Point Picking tool).
I'll add this this for the next release.
Re: Size Primitives
In previous release (I think 2.5.2) if I selected the plane in the properties appeared this type of information (width and lenght). Now there is only the box dimension of the plane and the center of this. Is or isn't possibile in 2.6.1? It is possible restore it or there is another method for know this kind of information?
Re: Size Primitives
As I said it's missing in 2.6.1 and I'll restore it in the next release.
