I noticed that when you select a local modelling in the Cloud 2 Cloud fonction, the split X,Y,Z tick box is grayed. Any chance we could have the split X,Y,Z option when a local modelling is used ? If I'm correct, there should not be any incompatibility with the fact that the reference point cloud is locally modeled.
Cheers and bonnes fêtes !
Dimitri
Split X,Y,Z component in C2C with local modelling
Re: Split X,Y,Z component in C2C with local modelling
Ah, that one was hard (for internal implementation reasons...). But now it works!
Thanks Daniel !
