last question,
on my process, is it possible to export only the c2c_dist (not the 2 decimate clouds) and fix a name (not use the cloud1_C2M_DIST_YYYY-MM-DD_HHhMM.bin)
And other question, when i use -GLOBAL_SHIFT {AUTO}, CloudCompare don't use the same shift if i import 2 point clouds. There is fonction to use the same shift for all import ? (edit:if i don't use -GLOBAL_SHIFT AUTO, CloudCompare make a shift (and not the same)
Render to file - command line
Re: Render to file - command line
You can remove the last part of the output filename (timestamp) with an option of the command line (can't remember the exact name right now ;).
I would have thought the 'AUTO' option would use the same shift (if possible)? Are you sure about that?
And which decimated cloud are you speaking about?
Hi daniel,
I'm sorry for not having replied before by it was the week end ...
It's ok for me, it's great with -NO_TIMESTAMPS option, and for the AUTO shift it isn't the same beacuase it's on different import ... so
Just have a last question (i hope) when i lauch cloudcompare.exe i have an error message :
Il 'ny a pas de disque dans le lecteur. Insérer un disque dans le lecteur \Device\Harddisk3\DR3
I think it's a problem with my computer (because on my other compurer CC works perfectly) Do you have an idea?
I tried to make a new install, but this message still appears.
Are you working with the Linux version? This error is a bit strange..
No i'm on windows, and i use Windows 64 bits.exe (i use the same .exe on other compurer and i don't have this message)
I really don't see where this message can come from then!
Here are some potential solutions (in French):
http://www.commentcamarche.net/forum/af ... ddisk3-dr3
That dosen't worrk.
It's not a problem, i lauch automate calcul on an other computer.
I have some bugs on my computer, i think a formatting is to provide
Thank's again Daniel
