I'm new to Cloud Compare, anybody now that how to call the poisson surface reconstruction in command line?
Best regards
Rui
Call poisson surface reconstruction in command line
Re: Call poisson surface reconstruction in command line
Calling a plugin in command line mode is not possible (yet)!
I would like to create a batch with the command line "Poisson surface reconstruction" but I searched at
http://www.cloudcompare.org/doc/wiki/in ... _line_mode
but I didn't find the command line in question.
I'm highly interested if the command line exist ?
Best regards
Laurent
Best regards
Laurent
Laurent Bitard
Hi, currently there's no such option (because up to version 2.9 it was not possible to call a plugin through the command line).
But in the particular case of Poisson, the plugin is based on a library (called PoissonRecon, by M. Kazdhan) and the command line tool is already provided by the author: http://www.cs.jhu.edu/~misha/Code/PoissonRecon
Thank you daniel, It works Perfectly !
Laurent Bitard
