Application failed to start and missing icuin52.dll
Posted: Thu Oct 23, 2014 9:32 am
Hi Everyone,
I'm attempting to compile the CloudCompare source code on Windows7 using Visual studio Express 2013 and I've ran into a problem.
I downloaded Qt( v5.3.2 windows 64 bit MSVS2013, openGL) and followed the wiki guide to configure and generate the binaries from the source code using Cmake and this was successful. I then opened the project in VS2013 and built the INSTALL sub-project that successfully created the CC_debug files in the install dir. I then changed the Debugging 'Command' for the CloudCompare and ALL_BUILD project to point to the CloudCompare.exe created when compiling INSTALL.
When trying the run the program I get the error "program can't start because icuin52.dll is missing". I can't find any reference to anyone else having the same problem. Do you have an idea what I've done wrong ?
[FYI - thought it wouldn't work but I gave it a try, copied in the dll that I downloaded and got the error "application was unable to start correctly (0xc000007b)" ]
Massive thank you in advance
Rob
Rob
