missing the dlls
Posted: Fri Nov 14, 2014 1:53 am
by zkbdx03
Hey ,
I'm trying to build the CloudCompare project,and I'm having a bit of trouble , hopefully someone can help me out.
Here is my configuration:
Windows 7 x32
QT 4.8
CMake 3.1.0-rc1 (windows GUI)
MSVC 2008
Now ,I have succeeded compiling the project. But when I run it, the Application failed to start and missing cc_core_libd.dll. So I copy the cc_core_libd.dll to the folder where
the CloudCompare.exe is. And then miss qcc_db_libd.dll. I copy the file to the folder then missing QCC_IO_LIBd.dll. Next ,with the same situation , I copy the QCC_IO_LIBd.dll,
msvcm90d.dll,msvcp90d.dll,msvcr90d.dll,Microsoft.VC90.DebugCRT.manifest to the application's folder.But it still failed!
I have no idea about it , hopefully someone can help me out. Thanks.
Re: missing the dlls
Posted: Fri Nov 14, 2014 3:51 am
Have you followed all the compilation instructions? Especially the 'Working with Visual Studio' section:
http://www.cloudcompare.org/doc/wiki/in ... on_Windows
Read the linked forum post as well, I believe it should fix your current issue.
Posted: Mon Nov 17, 2014 8:44 am
by zkbdx03
hey,Daniel
Thank you for your help.
I read the compilation instructions,but I miss the 'Working with Visual Studio' section. Then ,I follow the Working with Visual Studio's steps.
1. Compile the INSTALL project and check that all files are correctly copied in the CMAKE_INSTALL_PREFIX directory (under the 'CloudCompare' or 'CloudCompare_debug' folders depending on your configuration)
2. Edit the 'Debug' properties of the CloudCompare project (right click on the project and select 'Properties' at the bottom, then browse to the 'Debug' item in the left tree). Change the default 'Command' to point to the 'CloudCompare.exe' file in the installation folder.
But when I run the application in debug mode or release mode, "missing msvcp90d.dll" came up. I don't know why.I wonder that if there's a mistake with my VS08.
Posted: Mon Nov 17, 2014 8:45 am
by zkbdx03
hey,Daniel
Posted: Mon Nov 17, 2014 11:08 am
Indeed, the msvcp90d.dll file comes with VS2008. You could try to re-install/fix VS2008.
