Command Line - Del Scalar Fields - Add Height Ramp
Posted: Fri Jan 23, 2015 1:43 am
by 21nds
Is it possible, from the command line to:
1. Delete all scalar fields
2. use Edit->Colors->Height Ramp->Banding->Frequency 20->Direction Z
Thanks.
Re: Command Line - Del Scalar Fields - Add Height Ramp
Posted: Fri Jan 23, 2015 7:52 am
Nope ;)
I'll add this to the TODO list (but while the first one is trivial, the second might take more time...).
Posted: Thu Jan 29, 2015 3:19 pm
Okay it's done (two new options '-REMOVE_ALL_SFS' and 'CBANDING').
It will be available in the next release (or you can compile the code right now).
