Bare Earth Model (Point Cloud)
Posted: Sat Feb 21, 2015 7:54 pm
by la2er01
Hi
Can you tell me if it is currently possible to extract/develop a bare earth or lowest level model or PC set
from a point cloud in CC?
Regards
Kieran
Re: Bare Earth Model (Point Cloud)
Posted: Mon Feb 23, 2015 8:38 am
The 'Rasterize' tool is able to do that (with ' minimum height' option for the per-cell projection):
see http://www.cloudcompare.org/doc/wiki/in ... =Rasterize
But it might not work se well if you don't have a lot of poinst on the ground. So you could also look at the Canupo plugin to filter ground points only:
http://www.cloudcompare.org/doc/wiki/in ... O_(plugin)
