[SOLVED] Can't load my plugin once it embeds a QDialog window.
PabloC
Post by PabloC »
Hi!
I'm having trouble using my plug-in in Cloud Compare after trying to use a QDialog window as in the RANSAC plug-in.
My plug-in compiles flawlessly and gives the expected outputs if using fixed values but once I try to add a dialog window, it does not show-up anymore in the plug-ins list (even if it still compiles without problem.)
Is there any specific code to add in order to use a QDialog window inside a Cloud Compare plug-in?
Many thanks in advance.
Pablo C.
PS: The plug-in's code can be seen here
Re: Can't load my plugin once it embeds a QDialog window.
Hi Pablo,
Maybe it's something silly: can you try to replace the '.hpp' extension by '.h'. The CMake scripts are only looking for '.h' files (in order then to detect the 'Q_OBJECT' macros and generate the mocable files).
PabloC
Post by PabloC »
Fortunately you were right!
It's now time to change my naming habits.
Many thanks.
Pablo C.
