Importing MS 1000 data
Posted: Sat Nov 14, 2015 1:12 pm
by Urzatron
Hello. This is my first time working with this program, and I seem to have hit a (hopefully user error) snag. I am trying to import data from a MS 1000 profiler, except whenever I do the data is just a line. It registers all ~49,000 points, from what I can tell. The file is a .txt file. Any help would be appreciated!
Re: Importing MS 1000 data
Posted: Sat Nov 14, 2015 1:29 pm
What does the file looks like? Can you post the first lines maybe?
And maybe also the ASCII import dialog?
Sometimes this kind of issue is due to a wrong decimal character (e.g. a comma instead of a point) which prevents CC from reading the decimal values correctly.
Posted: Mon Nov 23, 2015 9:57 am
by Urzatron
I just found the solution. I had not selected a comma as the separator for the file data, since that is what appears in the .txt file. My bad!
