[FIXED] Align two point clouds by picking points pairs - Incoherent results
Posted: Wed Nov 18, 2015 7:22 pm
Hi everybody,
I'm working with CC (version 2.6.1, windows 64bits) to align:
- a high density point cloud (which corresponds to a panel with particular shapes scanned with laser)
- on another one containing the absolute position of some of its reference points.
For that, I use the "Align two point clouds by picking equivalent points pairs". I manually make the both point clouds roughly overlap for better visualization and point selection, and select the corresponding pairs.
My problem is here:
- When I select only 3 pairs (which is not enough), I obtain a coherent result, with RMS around 0.01m, which is what I expect.
- When I select 4 or more pairs, my panel makes a 180° turn, so the pair points are not coherent any more, and my RMS is around 1m (my panel dimensions are 1.5x1.5m)
Did it already happen for some of you, and is there a particular manipulation that I can do to force the alignment to be coherent ?
I have some screenshots if needed, I just don't know how to upload them...
Thank you very much in advance for your help !
Camille
My problem is here:
Camille
