.e57 import issue
hd_surveyor
.e57 import issue
Post by hd_surveyor »
When importing .e57 files with large coordinate systems is not shown the global shift/scale box, as it happens for other formats, with consequent loss of precision (2.6.2 and 2.6.3.beta versions).
regards
Alberto
Re: .e57 import issue
Can you send me an example of such file? (small if possible ;)
hd_surveyor
here a small sample http://we.tl/eCHLyXpyg5
Alberto
Ok this is fixed.
The Global Shift & Scale dialog should now appear in all cases (don't forget to click on "Apply all" otherwise the dialog will reappear for each scan).
You can test is with the latest online beta version right now.
hd_surveyor
are you sure that is already online?
I downloaded and tested the latest version (http://www.cloudcompare.org/release/Clo ... up_x64.exe) but has the same problem.
Alberto
Oups, you are right! Now it's ok :D
hd_surveyor
thanks, now works perfectly.
Alberto
