I'm having some issues while trying to create animations inside a building (or through a street...), I can't get clear viewports.
So I'm wondering if there is a way to better adjust viewports in dense places. (PS: I don't have any problems creating animations around my point clouds ... it's getting inside which annoys me)
Thanks!
Animation viewports
Re: Animation viewports
When you want to look 'inside' a cloud, you have to switch to 'Perspective' view. And it may be also a good idea to play with the 'zNear' parameter of the camera (see the Camera Parameters dialog). If you increase it it will remove more points in front of the camera.
Thanks Daniel, reducing the zNear parameter did the trick!
