Can't load stl file
Posted: Wed Jul 06, 2016 7:44 am
by Holg Spre
Hi!
I'm quite new in 3D data processing and want to work with CC. I created a .stl file by the use of a 3D photogrammetric scanner (GOM ATOS).
But unfortunately I can not open the file in CC.
When I start CC in the console it is written:
[ccGL Window::paintGL] OpenGL error: invalid enumerator
When I try to open a .stl file a new window opens (Tag duplicated vertices) but CC do not response anymore ...
Has anybody an idea what I can do?
Thanks in advance!
Holg
Re: Can't load stl file
Posted: Wed Jul 06, 2016 11:47 am
What version are you using? Can you share the file with me maybe? (cloudcompare [at] danielgm.net)
Posted: Sun Jul 10, 2016 8:46 pm
by Holg Spre
I use Version 2.6.0 ...
For sure I can share the file with you. You can just download it by:
https://polybox.ethz.ch/index.php/s/dpIVMZ66QZOek0x
Posted: Sun Jul 10, 2016 9:39 pm
I'll test it asap.
Meanwhile can you test it with the 2.7 version?
Posted: Mon Jul 11, 2016 6:28 am
I confirm that it works well with the 2.7 (or 2.8 beta) version. It should also be ok with 2.6.3 version.
I remember there was a bug at a time with the vertex merging algorithm (it was using a way too deep octree level to perform, which resulted in a awfully slow process on small models.
Posted: Sat Jul 23, 2016 3:47 pm
by Holg Spre
Sorry for my late response!
Although I recently updated the drivers of my graphic card, it does not fullfill the requirements for CloudCompare 2.7 (OpenGL 2.1). So I fear that I will not be able to use CloudCompare ...
Thanks for you're help!
Posted: Sat Jul 23, 2016 3:51 pm
You can still install the 2.6.3 beta version (there's a post with the links - something about "Windows 10").
Posted: Mon Jul 25, 2016 7:16 am
by Holg Spre
o.k. that sounds good. But, sorry I can't find the post or download file of version 2.6.3. Not in the cc-forum or on google...Do you remember the title of the post or perhaps the week or month to reduce possibilities?
Posted: Mon Jul 25, 2016 7:28 am
Posted: Mon Jul 25, 2016 9:35 am
by Holg Spre
Hey Daniel!
Thx a lot! Now it is working!
Cheers, Hol
