Faro .fls import questions
Posted: Mon Dec 05, 2016 12:03 pm
I have to have access to the unfiltered scans of a Faro Focus 3D. I have 27 projects, with 5 scans per project. I am able to this in Faro Scene, which is very tedious. More over, you can't let Scene work by itself since the default filtered is deactivated during the processing, and you have to accept by clicking in a window upon the loading/processing of each scan. In other words, very long process,that cannot be automated.
I would thus like to use the command line operation of CloudCompare. The workflow would thus be:
- load the original, unprocessed .fls file (with the -O {filename} command line option). However, I would like to know if the Faro default filter (in Scene, Tools/Options/Default filter box checked) is applied. If it is, is there a possibility of not passing through the default filter when loading in CC?
- transform the data using the registration information obtained from Scene registration process ? (with the -APPLY_TRANS {filename} option)
- export in .xyz file (with the -C_EXPORT_FMT {format} option)
The questions are thus:
- is it possible to import a .fls file without the default filter ?
- and by chance, does anyone know if one can export the registration information in Faro Scene 6.2 to build the transformation matrix ?
Thanks !
Robert
Thanks !
Robert
