CC 2.6.3beta crashes when file was load.
pieklo
Post by pieklo »
Hi
I have problem when I try load any cloud then CC was crashes. I have very old laptop with core2duo t8300 4gb ram and chipset gm965 (integred graphic card gma x3100), and i think that is a problem. Is there any way to make the program work?Image
thanks
Re: CC 2.6.3beta crashes when file was load.
You can try to disable all fancy options in the 'Display options' dialog (load clouds on GPU for faster display, color scale shader, etc.).
But the issue is probably related to the old graphic card (can you at least update the driver?).
pieklo
Post by pieklo »
Ok I click off GPU acceleration in display options and works fine. Thanks :)
