cross_section
Posted: Thu Jan 26, 2017 9:16 am
Hi everybody,
I cut a colored ply using the cross function, it's magic. After 24h of calculation, I have a lot of .bin file
Is there a parameter to specify the output format?
I would like to save the cross parts in binary .ply
In the meantime I wanted to convert .bin to ply with the following command, but the * does not work ...
CloudCompare.exe "-M_EXPORT_FMT PLY -PLY_EXPORT_FMT BINARY_BE -O * .bin -SAVE_MESHES
Is there a parameter to process all the elements of a folder?
Thank you in advance.
