Hello, how i can append own properties to object in my plugin?
With help m_app?
Own properties in plugin
Re: Own properties in plugin
I try to add object to database in my plugin, for exampledaniel wrote:Could you be more specific?
ccHObject *group = new ccHObject("GroupName");
m_app->addToDB(group);
m_app->refreshAll();
-Name GroupName
-Show name
-Info Object ID:...
-Current Display 3D View 1
My question is:
How can i create object of db with its own properties, for example
-Filename filename.txt
-Dir /usr/lib
-Special_field special_information
Hum, I don't think it's possible right now as everything is managed in ccPropertiesTreeDelegate which is a component of the CloudCompare project (and it's not aware of the plugins).
The only thing you can do is add these pieces of information as 'meta-data' (in which case they will appear at the end of the properties list, with one row per meta-data).
Daniel, thank you for your answer.daniel wrote:Hum, I don't think it's possible right now as everything is managed in ccPropertiesTreeDelegate which is a component of the CloudCompare project (and it's not aware of the plugins).
Must i use setMetaData(QString key, QVariant data)?
For example:
group->setMetaData("Filename", "text.txt" );
Ah! It's because it's only displayed for point clouds, meshes, facets, polylines and sensors for now ;)
I can extend it to groups if you wish?
It would be great to extend it with custom Object(ccCustomHObject). So there won't be fields required by object type(like width, height etc in image) , only from setmetadata.daniel wrote:Ah! It's because it's only displayed for point clouds, meshes, facets, polylines and sensors for now ;)
Okay, to make things simpler, all objects meta-data are now displayed, whatever the object. The github repo has been updated.
Daniel, thank you for your answers!
Is it possible now to show metadata of a ccCustomHObject?
I found a workaround like this,
CC_CLASS_ENUM ccTestObj::getClassID() const
auto id = ccHObject::getClassID();
id |= CC_TYPES::SENSOR;
return id;
but my ccTestObj is not a SENSOR, so is there any other way to do that?
return id;
