Cloud to Mesh Outputs
Posted: Fri Mar 03, 2017 4:38 pm
As always, thanks for your hard work. This is a great creation, cloud compare.
I have 4 questions;
1. Alignment Necessary?: If my clouds are in the same coordinate system, do I need to align them before I use cloud to mesh? I'm trying to compare the performance of my proposed method of topographic data collection, to a UAV derived data set. I feel that aligning them before running the distance computation would artificially improve the C2M results....do you agree with my logic?
2. Statistics of Results: I'm using the cloud to mesh comparison, and it seems to have worked well.
I understand there isn't really a report associated with the tool that will tell me about the results? Is that right?
I'd like to have a go at the results in terms of general stats, max, mean, etc, etc.
I thought I could export to excel, but my cloud is >2m points, which is above the limit of an excel sheet.
Basically I'd like quantitative results to report, and to accompany the visualization of the distance.
3. Error estimates: The software reports the distances acquired in the c2m tool, but is there any error estimates that can be reported?
4. Rasterization: I want to bring my resultant c2m distances into arc map. I know from past discussions with you (under an account I can't recover - I used the "forgot my password" option, but it can't find my email address. however when I register a new account with that email, it says it's already in use....I used another address and here I am....incase this bug is of interest) that you're not super familiar with arc map. I'd like to output my results as a rasterized tiff. I wonder if rasterizing the c2m results are resampling them (results are not uniformly spaced, rasters are) there by introducing small error. This error is I'm sure very minimal, but I wonder if there is a way to know the error?
Thanks in advance,
Lindsay
I have 4 questions;
Thanks in advance,
Lindsay
