I wanna know that is there any option that enables the auto-select of the
point clouds?
I'm loading many point clouds and wanna select them by clicking one of
their points.
Auto-select option for point clouds
Re: Auto-select option for point clouds
Not sure to understand... can you be more explicit maybe?
Anyway you have several options to select entities:
- click on the entity on the 3D view (this feature is sadly not supported by all graphic card drivers, we need to modify the way it works)
- press the ALT button and draw a rectangle on the 3D view. CC will then select all entities inside this rectangle
- click on the entity in the DB tree
- press the CTRL button and then select several entities in the DB tree (not necessarily contiguous)
- press the SIFT button and then select a first and a last entity in the DB tree (all entities between them will be selected)
- use the CTRL+A shortcut to select all entities in the DB tree
