Dear Daniel,
I would like to know is there a way to project point cloud onto plane which is fitted from these points?
I am using different tools for this task to fit 3D circle. The main idea is a projection of points onto planar surface, it is a plane which fitted from point clouds and second task is a fittting 2D circle to projected points . Afterwards, we can generate the circle center and radius (center x,y,z and r).
Cheers.
Point Projection onto Fitted Plane
Re: Point Projection onto Fitted Plane
Well, it's not accessible to the user but in the code this is definitely possible. Is it what you are looking for?
is it possible to add it as a tool to CC? it would be useful.
thanks.
thanks.
