Page 1 of 2
RANSAC Plugin
Posted: Wed Jun 07, 2017 4:59 am
by oth
i have been working with your software for serval days and i really appreciate your work.
though i have some questions about the RASNAC plugin. i'd like to have global informations about the parameters e, b, max deviation and the overlooking probanility.
i'd like to know what does each parameter change on the final result too.
also what is the unit of each parameter.
and thank you for your help sir.
Re: RANSAC Plugin
Posted: Wed Jun 07, 2017 6:53 pm
I think there's another message about this on the forum, and more importantly you should refer to the article (see
http://www.cloudcompare.org/doc/wiki/in ... n_(plugin)).
The plugin is a simple portage of the original author's library and therefore all the credits (and advanced questions ;) ) should go to him :D.
Re: RANSAC Plugin
Posted: Sun Mar 20, 2022 8:30 am
by yaren.ornek
Hello, I am wondering how to choose the parameters, how to find the most correct parameter. I would be glad if you help.
Re: RANSAC Plugin
Posted: Tue Mar 22, 2022 11:07 am
Ah, that's not easy. The latest versions of CC have a slighlty more explanatory GUI, but if it's not sufficient, then I guess you should read the article by Schnabel et al.:
http://www.hinkali.com/Education/PointCloud.pdf
And for the records, the plugin documentation is here:
https://www.cloudcompare.org/doc/wiki/i ... n_(plugin)
Re: RANSAC Plugin
Posted: Tue Feb 07, 2023 11:30 am
by Flow
A new question about the plugin "Shape detection".
If I have applied the plugin and show me only cylinders. Can I set that the program shows me only cylinders whose radius is smaller than, for example, 0.5m and the height is less than 3.0m ? This would allow me to sort out all incorrectly detected shapes.
The problem is that when I apply the algorithm, the program also shows me walls and ceilings since they also have a "radius".
Re: RANSAC Plugin
Posted: Wed Feb 08, 2023 7:10 am
As discussed by email, you would have to use the new options to filter by radius (in 2.12 and 2.13.alpha versions)
Re: RANSAC Plugin
Posted: Tue Feb 14, 2023 8:25 am
by Flow
Another question from my side:
If you applied the RANSAC algorithm and you created a Smooth Geometry (primitive) from the shapes you found, is it possible to assign different properties to the created planes/cylinders like a text (material, general description, volume/mass, different values, ...).
Re: RANSAC Plugin
Posted: Thu Feb 23, 2023 10:12 pm
Oops, I totally missed this message.
Are you asking whether you can do it programmatically or manually?
Re: RANSAC Plugin
Posted: Fri Feb 24, 2023 9:16 am
by Flow
i wonder if i can manually add specific properties (a text) to the geometric solids found in CC. Is this possible?
Re: RANSAC Plugin
Posted: Sat Feb 25, 2023 4:19 pm
Well, you can only rename them... (with F2).
And even if we would add a method to add some "meta data" (wouldn't be too hard), then they would only be visible in CC (and not exportable). Not sure if that would still be of interest?
