when I try to load a CAD-Modell I always get a problem with round objects, they are all hexagonal. I tried several different format like STL, DXF, DWG, etc. The only format which is running well ist OBJ
does anyone know this problem?
THX
OZI
CAD-Modell ist loaded in a wrong way
Re: CAD-Modell ist loaded in a wrong way
This is due to tesselation (all the mesh formats are triangular ones and the CAD software needs to convert the parametric surfaces to a set of triangles.
Generally you have some options regarding the tesselation density / precision in your CAD software.
Thanks for your quick response
If I understand you correct, I have to check the parameters of the software which is creating the CAD-Model. The smaller the triangles are, the rounder the objects will be, correct?
Thx
ozi
Thx
ozi
Yes. Generally it's more a parameter related to the number of triangles, but I guess a smaller size will work as well.
