Classify by colors
Antoine_27
Classify by colors
Post by Antoine_27 »
is it possible to classify a cloud of points from the colors under cloudcompare.(Survey drone)
Thank.
Re: Classify by colors
Nope, there's no classification algorithm based on the RGB colors. You can select the points based on each of their RGB components separately (by converting them to scalar fields, and then using the 'Edit > SF > Filter by value' method). But that's a bit tricky ;)
