Noise filter in command line
Posted: Mon Oct 02, 2017 9:58 am
by angup143
I want to process a large number of files using the Noise filter and was wondering if there was a command line utility for it? Found this
http://www.danielgm.net/cc/forum/viewto ... line#p4103 from two years ago which says there isn't a command line utility, but thought I'd check again since it's been a while since then.
If not, is there any way to batch process a number of files using the GUI?
Thanks!
Re: Noise filter in command line
Posted: Mon Oct 02, 2017 7:13 pm
Posted: Mon Oct 02, 2017 7:21 pm
by angup143
I did find the SOR filter utility, but noise filter
http://www.cloudcompare.org/doc/wiki/in ... ise_filter is giving me better results, hence why I was trying to find the command line version for it.
Thanks for getting back to me!
Posted: Wed Nov 27, 2019 4:54 pm
by A2G
As Angup143 above of this topic, I would like to use Noise filter in command line because I have best results with this tool (in comparison with SOR filter on walls) Does a command line exist for it ?
Thanks a lot,
Guillaume
Posted: Wed Nov 27, 2019 9:20 pm
Nope, this tool has not been ported to the command line yet...
