Is there a way to smooth this roads out?
Posted: Mon Feb 26, 2018 6:00 am
by NaikJoy
I'd want to make the roads look cleaner and still somewhat have its shape.. when I tried some tools it only made it looked like an avalanche went over them.
Re: Is there a way to smooth this roads out?
Posted: Mon Feb 26, 2018 8:22 am
Yes, the Delaunay triangulation algorithm uses all the points and therefore it's very sensitive to noise.
You may want to use the more robust 'PoissonRecon' algorithm (
http://www.cloudcompare.org/doc/wiki/in ... n_(plugin)) which gives a smoother result.
Another option might be to smooth the Delaunay mesh afterwards (Edit > Mesh > Smooth (Laplacian) (
http://www.cloudcompare.org/doc/wiki/in ... Laplacian)).
Posted: Tue Feb 27, 2018 6:35 am
by NaikJoy
Oh I think I'm up to something.. I think the best way is to just use zbrush..polygroup the roads and smooth em..
