Basic theory
Posted: Thu Oct 25, 2018 4:23 pm
Hello, I am new to CloudCompare and have a basic question. I am using CloudCompare for change detection (vegetation, subsidence) using a time series of aerial survey photogrammetry point clouds.
My understanding is that the fine registration function aligns two clouds in the X and Y. Z is not aligned because the cloud/cloud distance function outputs the Z difference. Is this correct?
Also, my point clouds were georeferenced using an on-board GPS . This means there may be some distortion in the point clouds due to the inaccuracy of the GPS, particularly the Z coordinate. Any advice here? E.g. rebuild point clouds without GPS coords? Perhaps I can focus on a small sub-area where distortion is likely to be minimized? I have also considered rebuilding the point clouds after first editing those GPS coordinates where the Z coords is obviously inaccurate..
I appreciate my issue may be more related to the accuracy of the initial photogrammetry processing (rather than CloudCompare), but would greatly appreciate advice here if possible.
Thanks,
Mark
Thanks,
Mark
