Extract several slices or contours
Posted: Sun Jul 21, 2019 12:52 pm
by p..
Hello
This is my first post, welcome everyone.
I have a question about creating several contours.
It follows the tutorial on Extract several slices or contours:
https://www.cloudcompare.org/doc/wiki/i ... ss_Section
My problem is that instead of creating a few contours, it creates one. I do everything as in the tutorial but unfortunately it does not work out. I can not figure out why this is happening. Please help me solve the problem
Re: Extract several slices or contours
Posted: Sun Jul 21, 2019 1:36 pm
Two options:
- either your slice thickness is too big (which prevent the 'multiple slice extraction' mode to work properly, as the slice is translated of its own thickness each time)
- or you use the 'single slice extraction' tool instead of the 'multiple slice extraction' one?
Posted: Sun Jul 21, 2019 6:35 pm
by p..
Thank you for your help the first option helped;)
And there is a tutorial in a way that you can create grid surfaces from a point cloud ?
Posted: Sun Jul 21, 2019 6:57 pm
Not a tutorial, but some documentation: https://www.cloudcompare.org/doc/wiki/i ... =Rasterize
