Command line mode new functions request
olegpetin
Post by olegpetin »
Hi, Daniel! Thank you for the greatest soft (the best point cloud processing soft in the world!).
Please, add in TODO list new command line mode functionalities:
*** 1 ***
-SF_CONST {SF name} {constant value}
Creates, names a new scalar field, filles constant value to each point, and sets SF active
*** 2 ***
-SFS_OP {SF1 index} {operation} {SF2 index}
applies an arithmetic operation on a given scalar field (SF1) of the loaded cloud/mesh and with a given scalar field (SF2).
SF = SF1 (+,-,*,/) SF2
The scalar-field index starts from 0. The user can use the keyword 'LAST' to designate the last scalar field.
Supported operations are:
add
sub
mult
div
Notes:
the updated cloud/mesh is automatically saved (see the AUTO_SAVE command to change this)
the modification is done in new place (i.e. the new scalar field is created)
*** 3 ***
-SF_DEL {SF index}
deletes an active scalar field.
*** 4 ***
-SF_TO_COORD {SF index} {dimension: X, Y or Z}
sets an active scalar field as specified coordinate (dimension).
*** 5 ***
-SF_RENAME {SF index} {new name}
renamed an active scalar field.
All the best
Oleg
krillmcrawl
Re: Command line mode new functions request
Post by krillmcrawl »
I'm also very interested in nr 1 from you suggestion:
*** 1 ***
I looked at the command line parameters but could not find it here:
https://www.cloudcompare.org/doc/wiki/i ... _line_mode
Do you know if it's already implemented but maybe using another name?
