Compare two point cloud
Posted: Tue Oct 16, 2012 6:47 am
by yangyuanyuan
Hi
I am a beginner,and I have two point cloud about ladsides.
I want to ask you how can I compare it? so that generating variable quantity.
Thank you very much!
Re: Compare two point cloud
Posted: Tue Oct 16, 2012 9:52 am
I've updated the 'How to compare two 3D entities' tutorial on the wiki to a more generic version:
How to compare two 3D entities http://www.cloudcompare.org/doc/wiki/in ... D_entities
Posted: Tue Oct 16, 2012 1:22 pm
by yangyuanyuan
Hi
When I input the file (ASCII.txt) to the CloudCompare, It will get an error: Reading error(no access right?). How can I treat it?
Thanks!
yangyuanyuan
Posted: Tue Oct 16, 2012 1:40 pm
Is there any chinese character in the file name or file path?
Otherwise it may be because another program is using the file (in a quite exclusive way!).
Posted: Wed Oct 17, 2012 3:43 am
by yangyuanyuan
Hi
I want to ask you how to get the compared value from the computing distance? The other words:What's the meaning of the computing distance value?
The two point cloud from the same TLS.
Thanks!
yangyuanyuan
Posted: Wed Oct 17, 2012 7:24 pm
the distances are by default the distance from each point to the nearest point (or triangle if your are comparing your cloud to a mesh).
Here are the details:
http://www.cloudcompare.org/doc/wiki/in ... omputation
