Dear Daniel
Posted: Thu Feb 13, 2020 7:43 pm
by BiancaBarreto
Dear Daneil
I would like to know which mathematical formula is used in the diagram to calculate the roughness index.
Re: Dear Daniel
Posted: Thu Feb 13, 2020 9:07 pm
No real formula, but the computation of the best fit plane on the points neighbors (see
https://www.cloudcompare.org/doc/wiki/i ... =Roughness).
Re: Dear Daniel
Posted: Tue Mar 03, 2020 4:38 pm
by Yehoshua
It looks like you have a few questions about the roughness calculation. I know you have written out a description of how it is calculated but would this formula be an accurate representation of your description?
Rj=(|ΔZ1|+|ΔZ2|…|ΔZi |)/n
where R is roughness calculated for points within a kernel radius of j, 𝛥Z is the difference in elevation from a measurement point and the least squares plane calculated by the nearest neighboring measurement points and n is the number of measurement points within a kernel radius.
Re: Dear Daniel
Posted: Tue Mar 03, 2020 9:39 pm
Actually the roughness value for a single point is directly (and only) the distance from this point to the best fitting plane. There's no sum or average.
