Hello!
I am having a trouble loading dense cloud file (.las), the programm says:
[12:18:11] PDAL exception 'Unable to open stream for 'Sliter.laz' with error 'No such file or directory''
[12:18:14] An error occurred while loading 'Sliter': the third-party library in charge of saving/loading the file has thrown an exception
How the following problem can be solved?
Thanks,
Kriss
Error loading .laz file
Re: Error loading .laz file
Do you maybe have some spaces or 'foreign' characters in the file path?
No, it contains only Latin letters, have no idea what could be the problem
Can you maybe share the file with me? (admin [at] cloudcompare.com)
I just sent you the file
Oops, it seems I didn't receive it!
Can you maybe try on my personal email? (daniel.girardeau [at] gmail.com)
I did it to second email also, sent as google drive file.
Ok, this time it worked.
And I could load the file without any issue (with the latest 2.11.beta version). I could also export it to LAS, reload it, etc.
If it still doesn't work with the 2.11.beta verison on your side, can you maybe paste here the full path to the file? Or move the file somewhere else (in "C:\Test" or equvialent) and try to load it again?
Thanks, yes now it works, when I moved the file :)
So it was indeed an issue with the file path... For the records and our understanding of the issue, can you paste here the previous path?
