DELAUNAY Triangle lib error - CGAL
Posted: Mon Jun 08, 2020 6:46 pm
I originally wrote a test program using the Windows version of CloudCompare and amongst other steps it uses the DELAUNAY Best Fit function and worked fine.
I'm now moving the project to a Linux docker and have run into the following error...
[17:51:36] [ccMesh::Triangulate] Failed to construct Delaunay mesh (Triangle lib error: CGAL library not supported)
From the change log I find this...
2.6.3
* Triangulation:
- due to licensing issue with Triangle lib (incompatibility with GPL/LGPL) CGAL is now the prefered library for 2.5D
triangulation CCLib can now be compiled with CGAL support using COMPILE_CC_CORE_LIB_WITH_CGAL.
- please note that as CGAL 2D triangulation module is released under GPL license. A version of CCLib compiled with CGAL
support is no longer licensed under LGPL (GPL is "viral"). To keep CCLib original license scheme, you *must*
compile it without CGAL.
- as a positive side effect, micro benchmarks show that CGAL tends to offer better performances.
I'm afraid from that I can't figure out what the situation is. It sounds like to use DELAUNAY I'm going to need to compile CloudCompore with CGAL, but if I do it won't be GPL, which I assume is because CGAL isn't free?
If this is the case, then why does it work fine in the Window version 2.10.2 downloaded earlier this year?
Tom
2.6.3
* Triangulation:
Tom
