Colors
Albersonb
Colors
Post by Albersonb »
I am a new CloudCompare user. I am trying to merge two pts files that I have exported FARO Scene and Agisoft Photoscan. I was able to merge the clouds successfully and export. However, whenever I import the newly merged point cloud file into VC4 and Recap the FARO Point cloud points import as blue. The photoscan points are the correct color. Any help would be greatly appreciated. Thanks so much?
Re: Colors
To which format have you exported the merged cloud?
If it's pts, be sure to select the right order at export time (select '[PTS] point, SF(s), color, normal').
