DEFINE USER COORDINATE SYSTEM (UCS)
Posted: Fri Sep 04, 2020 12:02 am
Hi everyone,
I'm new in the forum. CC is an amazing software guys!
I'm trying to draw the cross section of a retaining wall scanned using a laser scanner (the one that you can see in the "screen_1" attached).
From the entire points cloud I cut out a smal portion rapresenting the transversal section of the wall that I need to retrace (see the "screen_2" attached).
I just want to reproduce the wall in sketchup pro 2020, are there plugins that can help me?
Right now the only method that i found is to create a polyline using Extract Section command and than import it in sketchup.
The problem is that I need to change coordinate system and makes it perpendicular to the plane containing the section of the wall in order to correctly draw the polyline.
So, is there a way to change coordinate system and makes it paralel to the normal vector of a plane (see the "screen_2" attached).
So that I can draw a polyline on the plane that I have create using Extract Section (in Segmentation tool).
Thank you all.
Thank you all.
