Colorize ply extension object
Posted: Tue Feb 05, 2013 9:31 am
by mbrochier
Cloudcompare bugs while trying to apply a color on a Mesh object (*.ply file).
Fonction Edit/Colors/Set unique doesn't work on Version: 2.3.Qt/MinGW - 09/19/2011
When i try to apply a color on a mesh object, the logiciel bugs.
First I select the Mesh of my *.ply file imported in Cloud Compare
Then I activate the fonction Colorize
As I click on OK an error window appears and cloudCompare closes.
Thanks in advance
Re: Colorize ply extension object
Posted: Tue Feb 05, 2013 9:55 am
Hi, this version is quite old ;)
I'm pretty sure it has been fixed long ago. You should get the latest version here: http://www.cloudcompare.org/release (I've just test with the 2.4 - 01/13/2013 version).
