Reprojection with GCPs
Posted: Thu Jun 17, 2021 10:38 am
by undefined Solutions
I serched online and in this forum but I did not found a solution to my problem...
I have a Pointcloud and two list of GCPs one with an EPSG-System an one custom coordinate system.
Is there a workflow to add the EPSG-GCPs and then match the custom-GCPs?
I am realy new to CloudCompare and feel a little bit lost -.-
Re: Reprojection with GCPs
Posted: Thu Jun 17, 2021 11:29 am
I guess you can use this tool: https://www.cloudcompare.org/doc/wiki/i ... itle=Align
And mind that you have to accept the Global Shit when loading the GCPs with an EPSG system (the original coordinates will be applied at export time - and that will be the same for the aligned GCPs)
Posted: Thu Jun 17, 2021 11:53 am
Ok, this could work but I have ~70 point clouds and 100 GCP over all -.-
and all all GCP manually is not possible...
Perhaps you have an solution for me?
Posted: Thu Jun 17, 2021 12:24 pm
What's the relationship between the EPSG GCPs and the ones with a custom coordinate system?
Are you expecting some kind of auto-matching?
Posted: Thu Jun 17, 2021 12:52 pm
I do not know the exact relationship, I did only get thes two CSV-Files.
EPSG GCP-locations with one point cloud
local GCP-locations
It would help me already if it would be possible to load the list of Positions into this align tool...
Posted: Thu Jun 17, 2021 3:08 pm
Indeed!
Are the labels the same on both sides?
Posted: Thu Jun 17, 2021 6:40 pm
Yeah the Labels are on both sides the same points in different coordinate systems...
Posted: Thu Jun 17, 2021 7:45 pm
Can you send me a couple of example files? (global and custom GCPs)
To admin [at] cloudcompare.com
Posted: Wed Jul 14, 2021 6:10 pm
Sorry for the delay in answering...
I have since learned how to move from the coordinate system NAD83(2011) / South Carolina https://epsg.io/6569 into a local coordinate system. I have been given the following parameters:
Delta X: 497104
Delta Y: 338987
Rotation: 32.68° clockwise
Is this reprojection possible in CloudCompare?
Thanks for the effort!
Posted: Thu Jul 15, 2021 9:50 pm
Shifting would be easy (just use these Delta X and Delta Y as Global Shift when loading the GCPs). Then, for the rotation, you should be able to use the 'Edit > Apply transformation' tool?
