Mesh measure volume if some faces normal are flipped
Posted: Sun Jul 18, 2021 5:02 pm
This tool is accessible via the 'Edit >> Mesh >> Measure volume
For example
It is not easy to scan with eyes hundreds of mesh tringle color to check if one has flipped normal
Even Edit >> normals >> compute does not correct normal (I have to use Blender or FreeCAD etc)
Any suggestion?
attached 3 files - Real volume is (8)+(0.99)
This tool can find any solid (closed) mesh volume and luckily gives warnings if mesh is open (has holes) or has non-manifold edgesMeasures the volume of a closed mesh.
For example
Unfortunately if closed mesh has flipped normal, this tool can give wrong volume result without any warnings[19:27:54] [Mesh Volume] Mesh 'Mesh': V=6.15324 (cube units)
[19:27:54] [Mesh Volume] The above volume might be invalid (mesh has non-manifold edges)
[19:28:36] [Mesh Volume] Mesh 'Mesh.section': V=5.60789 (cube units)
[19:28:36] [Mesh Volume] The above volume might be invalid (mesh has holes)
Any suggestion?
