DB Tree -> CC Object -> Property = Colors
Posted: Wed Jul 28, 2021 8:30 am
by quodlibetarian
Is there any way to change this property from Scalar Field to RGB for many objects in one command either in the GUI or commandline?
It is time consuming to change each object individually :)
Re: DB Tree -> CC Object -> Property = Colors
Posted: Thu Jul 29, 2021 1:21 pm
You can toggle color with 'C' and scalar fields with 'S' (see the equivalent 'Edit > Toggle (recursive)' menu options).
And with the command line you can't really change that as it's just display options (and they are only retained if you save the entities to BIN files)
Posted: Thu Aug 12, 2021 11:20 am
by quodlibetarian
Thanks.
