PDAL exception
Posted: Fri Sep 17, 2021 1:26 am
by daniel111
I am encountering an error with some files when attempting to save as a .LAS
PDAL exception 'writers.las: Can't write with template-based filename using streaming point table.'
An error occured while saving '.....las': the third-third party library in charge of saving/loading the file has failed to perform the operation
This can occur after loading a .las file and then immediately saving it as a .las. saving as a different filetype works, but the secondary processing (different program) is affected/doesn't flow as smoothly.
I am wondering if anyone has encountered this error or knows a source of the error.
This occurs ~10% of the time from collected point clouds.
Thanks,
Dan
Re: PDAL exception
Posted: Sun Sep 19, 2021 9:21 am
Are there any special characters in the filename or the file path maybe? That's the only obvious reason I see why you would have such an error...
If not, it would be good to send us an example file (admin [at] cloudcompare.org) so that we can try to reproduce the error on our side.
Re: PDAL exception
Posted: Mon Sep 20, 2021 12:28 pm
by Jälv
Your files must likely have a `#number` like `#1` `scan#2.las` in their name, and when saving it PDAL treats
the `#number` part as a placeholder that needs to be replaced.
Re: PDAL exception
Posted: Sun Oct 03, 2021 3:00 am
by daniel111
Yes there was a special character (#) in a parent folder.
Now removed, the saving is working without error.
Thank you for your help
