pan while segmenting and multi segment polygons
Posted: Fri Oct 01, 2021 8:49 pm
by PablerasBCN
please add option to pan while using scisors, it gets very frustrating not to be able to pan.
you could force user to hit space bar to pan since right click resumes polygon drawing.
Also is bit frustrating not to be able to input multiple polygons in one "sesions" of scisors tool but first request is much more important.
Re: pan while segmenting and multi segment polygons
Posted: Sat Oct 02, 2021 5:00 pm
by juacarri
You only have to click in the pause button to pan while segmenting.
Posted: Sun Oct 03, 2021 8:53 pm
by PablerasBCN
cool!!! I just checked, you know what is funnier, space bar triggers it on off!! problem solved tx a lot!
Posted: Sun Oct 03, 2021 9:40 pm
by PablerasBCN
I was going to segment some walls by a road, when I realized that if you're drawing a segmentation polygon, if you resume, the polygon is lost, total boomer, please make polygon be as it was just prior to pause!
Posted: Tue Oct 05, 2021 6:25 pm
by DA523
I use the mouse wheel and SHIFT to pan pointcloud
But how to pan pointcloud and polygon together?
Posted: Tue Oct 05, 2021 6:34 pm
That's the not the way this tool is designed / thought.
There are indeed two glitches that allow you to move the cloud without moving the polygon:
- export the polygon (save it) and then reload it while in pause mode. You'll then be able to pan the cloud while the polyline remains at the same position (as it's attached to the screen coordinates).
- use the shift+mouse wheel trick indeed
But both options are actually glitches ;).
