Saving .las in Linux
Posted: Wed Jan 19, 2022 4:08 pm
by rnal
I have a point cloud in .las which I am able to load in CC. I ran the CSF filter and obtained ground points, then I wanted to save this back to a new point cloud. However, when I try to use "save" it keeps saving it to the default .bin format and there is no option to change the format (no scroll down menu). In other apps I usually just type the extension after naming the file when saving, but this has not worked in CC case.
Is there a way to save to .las?
Re: Saving .las in Linux
Posted: Thu Jan 20, 2022 9:06 am
Are you sure you select a single point cloud? LAS files can only save a single point cloud.
And make sure you select the cloud and not the group/folder that contains it.
Posted: Thu Jan 20, 2022 10:30 am
by rnal
Hi, yes I am selecting only one point cloud and it is the specific cloud rather than the folder containing it. I have the same issue if I try to save it as .txt file too.
Posted: Thu Jan 20, 2022 10:47 am
What does the save dialog looks like on your side?
On Windows you have the 'Type' field:
I would have assumed Qt was providing more or less the same interface on all systems...
Posted: Thu Jan 20, 2022 1:24 pm
by rnal
Hi it looks a bit different. There is no "choose file type" option.
Screenshot from 2022-01-20 12-10-19[28785].png (637.69 KiB) Viewed 1897 times
Posted: Thu Jan 20, 2022 1:44 pm
And what about the drop down menu in the bottom right part?
It looks like it's just too short but it looks like the 'Type' field.
Posted: Thu Jan 20, 2022 1:56 pm
by rnal
That seems to have worked, actually.
Thank you!
Posted: Thu Jan 20, 2022 3:02 pm
I guess that's a Linux way of presenting things then ;)
